Beiträge von Renato
    Wenn ihr gerade so schön am Vermessen seid, wie sieht es aus, wollt ihr nicht mal den ganzen W50 vermesse, dann könnten wir die Maße sammeln und ein Skizze anfertigen und hier mit einstellen? Aus den Maßen könnte man auch ein schönes 3D Modell kreieren, ich brauche nur die Maße.
    Also messt was das Zeug hält und her mit den Maßen, die werden immer wieder gebraucht!
    Nein, die sind mir nicht bekannt, da ich im Moment nicht an das Fahrzeug komme, aber hier sind ja noch mehr User, die einen LAK haben, also los Jungs.
    Die Einbauten sind verklebt und geschraubt, siehe mal hier auf der HP unter Ausbau zum WoMo nach, da kannst Du einiges dazu sehen. Ich habe mir Dichtungen selber gebaut aus alten Schläuchen (schön weich).
    Hello Renato!
    It was with great pleasure I read your post on the Steel Soldiers Web Site! They started that thread just for me! I was totally given the brush off by most of these
    guys when I first posted on there. I was excited about my truck and was just telling
    them the features and specifications and it was like everybody had something to say
    to the contrary of the facts! They said the Pneumants could not handle that much weight and that the truck couldn't haul that much and on and on! I know after they
    see your absolutely awesome story about your adventures in the Mighty IFA, they
    will maybe start to understand about this magnificent marvel of fine engineering!!!
    I am wondering the value of my W-50 as seen in the photos I had sent you when
    you first contacted me a while ago. I have had offers on it and have turned down a
    few good offers but not good enough! My truck now has 2,750 ACTUAL MILES
    on it! It only had 800 Miles on it when I aquired it! I would greatly appreciate it if
    you would tell me how much it cost to ship your IFA here to the states when you were here in 2004 I think it was. I would like to know the amount so I can use it to help figure an amount my truck is worth! Mine is the military version and I have the Original Delivery Receipt from the factory, The Original Build Sheet, Original Key, and even the tires are original! I have about $18,500.00- $20,000.00 US Dollars invested in my W-50 in Trade Value. I've told people it's $22,500.00 and some think
    it is too much, but I think it probably cost $50-$60,000.00 US NEW maybe? If you
    know what a 1982 military version sold for new, that would also greatly help me!
    If shipping is $10K US or so to here, then I should add that to the price, or most of it, because over there is the only place that they could probably ever find one for sale!
    I am fascinated with your adventures and can only dream about doing that! If I had a
    sponsor......
    Thank You Very Much For Your Time! I Greatly Appreciate Any Help With Determining the value of my W-50!
    Best Wishes To You And Your Family!
    Sincerely,
    Jeff Cheek
    Brentwood, Tennessee
    615.377.6577
    SO, ich war gestern mal beim Reifendienst mit der Fußwaage. Die Werte sind also nicht so ganz genau.
    Also:
    originale IFA-Felge komplett mit Sprengring ca. 55 kg
    Komplettrad 16-20 /70 Dneperosia montiert mit Luft ca. 120 kg
    Reifen Michelin 14.00 R20 X ohne Schlauch ca. 105 kg
    14.00 R20 montiert mit Felge ohne Luft ca. 145 kg
    Wie gesagt, ich habe die Reifen auf eine Personewaage gestellt und das war nicht sehr genau.
    Also ich habe meine ESP beim Boschdienst Knoll in Chemnitz optimieren lassen, das heisst, das Fahrzeug muss dort zwei Tage stehen und die machen daran Einstellungen auf dem Prüfstand (muss man angeben, ob man mit auf den Leistungsprüfstand mit dem Fahrzeug möchte) Kosten ca. 400,-Euro. Dort hat man schon bist zu 168 PS aus einem original W50 Motor rausgeholt.
    http://www.knoll-online.com/ unter Filialen -> Chemnitz ein Herr Kascha macht das.
